Surface mount Pico adaptor for MiniTiouner V2 PCB
£4.50
Whilst the PicoTuner was designed for use in a new tuner design it can also be retrofitted to the BATC V2 Minitiouner and similar designs providing their FTDI modules are fitted in sockets.
This involves removing the FTDI module, replacing it with an adaptor pcb and adding 5 wires to connect signals that are not present on the FTDI sockets. The advantage of doing this upgrade is to provide access to the second TS.
For full details and constructions note see: https://wiki.batc.org.uk/PicoTuner#Surface_mount_Pico_adaptor_for_the_MiniTiouner_V2_PCB
Note this is the blank PCB only.
21 in stock
