MiniTiouner version 2 blank PC
£6.00
The MiniTionuer USB tuner is at end of life has been replaced by the PicoTuner for most applications including HamTV reception – see https://wiki.batc.org.uk/PicoTuner for more details.
This is the version 2 blank PCB for the MiniTiouner USB tuner project – see https://wiki.batc.org.uk/MiniTiouner_hardware_Version_2 for project details
14 in stock
Sorry, but you can only purchase this item if you are a BATC member. If you are already a member, please login first, then come back here. If you are not yet a member, please consider joining us.
Join the BATC
SKU: 301 Category:
Description
This is the version 2 blank PCB for the MiniTiouner USB tuner project for use with the Serit tuner – note it requires all components, including voltage regulators, tuner and USB modules, to be bought separately.
SeeĀ https://wiki.batc.org.uk/MiniTiouner_hardware_Version_2 for project details.
Download build instructions:
https://wiki.batc.org.uk/File:Notes_on_building_the_BATC_v2_Minitiouner.pdf
Additional information
Weight .04 kg
