ALL orders to the USA will require payment of import tarriffs and duties (minimum 30% plus fees) by you to the courier BEFORE the shipment leaves the UK.
See https://forum.batc.org.uk/viewtopic.php?f=88&t=9233 for more details
Portsdown – LO filter board – BLANK PCB
£4.50
This is the BLANK PCB for the Portsdown DATV system multi-band switched local oscillator filter board
Project is now obsolete and PCB is no longer available
Out of stock
SKU: 208 Category:
Description
It is NOT the assembled unit as shown in the picture but just the BLANK PCB to enable home construction but please note it uses fine pitched SMD components.
It is highly recommended that you use one in the Portsdown transmitter – see https://wiki.batc.org.uk/LO_filters for more details and the parts list and schematics.
Additional information
Weight .01 kg
