Portsdown – 8 band decode – BLANK PCB
£3.50
This is the blank PCB to build the custom designed 8 band decode board for the Portsdown transmitter.
Note this is for the blank PCB ONLY and it is NOT required for the port 4 switch and band decoder.
19 in stock
Sorry, but you can only purchase this item if you are a BATC member. If you are already a member, please login first, then come back here. If you are not yet a member, please consider joining us.
Join the BATC
SKU: 209 Category:
Description
This 8-band decoder is designed to work with the 8-band RF output switch and the “Portsdown 2018” software.
It will provide switching signals (either always on, or PTT activated) to 4 Power Amplifiers and 4 transverters, and it also enables you to set which VCO filter should be switched in for the 4 transverter outputs.
For full details see https://wiki.batc.org.uk/8-Band_Decoder
Additional information
Weight .01 kg
